I've got a Frantz adapter installed on a transmission cooler line and instead of a TP filter installed I have a Magnefine Trans filter with fluid flow coming from the Frantz adapter. Now what my question is, is this. Is having a Magnefine hooked up this way a bad idea? I know I do not have 100% of the cooler line flow running through the Magnefine but at least some. Also if the Magnefine were to plug woould the bypass in the Magnefine work? I'm not sure if it would since I have the Frantz Adapter supplying the Magnefine.
