Posted by Irv
Very interesting post, which now makes me a bit uncomfortable running these. ???"
If my car wasn't under warranty, I would have run the Ultras. The Royal Purple tech I talked to this morning told me that in his opinion oil filter bypass specs by OEM's are a matter of design preference, rather than right or wrong. Cold start - No bypass event and somewhat reduced oil pressure vs bypass and unfiltered oil for a short time.
Our Impala is still under warranty too but I think I am going to use up what I have already purchased. No receipts, plus they are well past the 30 day return policy anyways.
I am curious if GM's TSB takes into account the use of synthetic oil with regards to this TSB? With better cold flow properties than conventional, I am wondering just how necessary using another filter is?
Also, since I have about 3 TG's on back up for this car, I wonder if the PSI settings on those are the same as the Ultra's?
Also, going by the info you provided, the Ultra, although just barely, is still in spec.
"Specifically, the Fram Ultra listed for my Impala has a Bypass Valve Setting of 9-15 psi. I just came across a GM service bulletin regarding the required spin on oil filter for my Impala, and the recommended GM filter Bypass Valve Setting is 14.5- 21.8 psi".
CVS, how did you come across this TSB? Was it mailed to you or did you find it somewhere else?
I find it funny/odd Fram would still recommend these filters for these Impalas with this TSB in affect?
Maybe some more research is in order, if I can find anything else?
Thanks for posting this up.
