Ya that about sums it it. The louvers do look consistent and fully open, albeit still small.Wonky base gasket and tiny louvers?
49” x 1.75” = 85.75 sq inAre you able to measure the area of the filter media? I'm keeping track of filter media area for a few different sizes of filters, and I'm missing this one.
I didn’t even notice the nubs before so I went and looked and yes I see what you mean, it solely relies on the “face” of that plate for a seal, the plate that’s all wavy …The leaf spring was a really good fit in the end cap because the "nubs" on the ID of the end cap hole makes it an interference fit. So the leaf spring needs to sit all the way down and seal on that thin raised ring on the end cap. If the leaf spring is warped and/or has lots of ruffles there simply will not be a good metal-to-metal "seal" . That's why there's a leak gap and why light shows up so prominently. Also possible that the interference fit with the nubs is too tight and won't allow the leaf spring to sit all the way down in the end cap. If that's happening too, it’s another separate quality issue, and makes the leak gap even worse.
Nubs.... and there is zero sealing going on between the ID of the end cap and leaf spring because the nubs leave a big air gap in that area. The only sealing interface is the leaf spring to that thin raised ring around the end cap hole. Only way it will "seal" is to have perfectly flat and smooth surfaces.
Yep, it's a very small sealing area, so if the leaf spring is warped and/or has a ruffled surface, and/or it can't sit down all the way to make good contact, then there's always going to be some level of leakage around the media. It being just a metal-on-metal "seal" means it has to be basically perfect to ensure any good level of sealing.I didn’t even notice the nubs before so I went and looked and yes I see what you mean, it solely relies on the “face” of that plate for a seal, the plate that’s all wavy …
Look at the last picture you posted, the one with the media cut away and the light shining in. You can see closed louvers that are not passing any light.Ya that about sums it it. The louvers do look consistent and fully open, albeit still small.
I’ll went and had another look and that’s just how it appears in the picture, must have been dark behind those louvers, they are all evenly open.Look at the last picture you posted, the one with the media cut away and the light shining in. You can see closed louvers that are not passing any light.
Ed
Lighting and ANGLES are very critical in evaluating Louvers!!I’ll went and had another look and that’s just how it appears in the picture, must have been dark behind those louvers, they are all evenly open.
And just what is this "experiment" suppose to prove?Interesting experiment using my closet door. Top to bottom horizontal orientation
Closed from inside
Closed from outside
Light originating from inside taken from outside
Close up of INSIDE seam that light originated from
The “Inside” seam would be equivalent of where bypass leak would enter into oil flow of cartridge.
I’ll let everyone judge for themselves as to what a “Flashlight Test” signifies.And just what is this "experiment" suppose to prove?![]()
It's pretty simple by using the light sensor called an eyeball.I’ll let everyone judge for themselves as to what a “Flashlight Test” signifies.
The fluid dynamics calculation shows the impact of a certain sized leak gap. The bottom like is a leak of xx% on a filter that's 99% @ 20u will decrease the efficiency to (99% - xx%) @ 20u. If you don't think it's pretty accurate, then go to that big Endurance thread, get the leak gap measurement dimensions given, and do a calculation to see what you come up with.Ah…
You want to extrapolate???
It’s perfectly flat where it sits. Correct?
And there lies the rub..
You take a sliver of light and attempt to
>>>EXTRAPOLATE <<<
Up to??leaking up to 15% past the media
Come on ... you've been hashing over this ruffled leaking leaf spring issue for literally months ... jumping in every thread it comes up in and trying to down play it and come up with every twisted rabbit hole "theory" and excuse to try and justify it as "no big deal" ... you own some First Brands or Champ Labs stock?, lolUp to??
So now we open the door to less than??
Maybe 5%??
Bingo!!So the leak can be anywhere from 0% to 15
Again …So the leak can be anywhere from 0% to 15%
So what's you're point? You should know that by now - see below why. This subject matter has been beat to a pulp, yet you never seem to really understand that the ratty leaf spring stamping quality is all over the map, and some are pretty horrible which would be pretty bad leakers. If you're "lucky" you might get one that only leaks 5%.Again …
Your words
Update ... I went back and looked at old threads when the ruffled leaking leaf spring issue first got attention ... and you were in all of those threads trying to justify internal leakage even back then. That was almost an entire year ago (Sep 2024)! How long is your crusade for leaky leaf springs justification going to go on?Come on ... you've been hashing over this ruffled leaking leaf spring issue for literally months ... jumping in every thread it comes up in and trying to down play it and come up with every twisted rabbit hole "theory" and excuse to try and justify it as "no big deal" ...
