Fram Tough Guard
North Alabama
What say the BITOGers about the Fram Tough Guard oil filter? any good?
I know the Extra Guard & Double Guards are loathed here.
nothing tough about that guard
Originally posted by BlazerLT:
If you have to get a Fram, get the Extended Guard.
I'll keep that in mind if I'm ever in a pinch.
For that matter, pretty much any Fram oil filter would work OK for a normal OCI, wouldn't it?
(Yes, I've seen the filter test pictures of the Fram filters.)
Please understand that I am talking about the Entended Guard and NOT the Extra Guard.
Two different filters with completely different construction and filtering materials.
Excellent filter.
Excellent filter.
Yes sir,
I understood you. Thanks again for the info.
Excellent filter.
Not entirely different. They share ADBV and bypass valve designs.
-T
I can say this about the Tough-Guard for the 3S-FE Toyota engine - this filter is small and mounts on the side of the block, so it's almost upside-down: after the car has been sitting for about 10 minutes, ALL the oil drains out of the filter. I had to take it off to tighten a coolant drain plug, and the oil had drained out of it. So much for the anti-drainback valve.
I have gone mostly to the Pure-1 based on BITOG info.
