FRAM Force 9688 new oil filter cut open
My last c&p was a used 9688 and it didn’t look very good so I figured I’d cut a new one open.
Thanks for the c&p. Picked up 9 of these for ~$20 from AAP close out for my daughter’s Santa Fe and was thinking of cutting one open myself before using. I’ll be happy to use these for her usual 4-5k mile OCI.
Looks OK. I just swapped out a PH7317 off my son’s ‘07 K24 Accord after 6500 miles, it looked uneventful other than a fair amount of carbon in the lower pleats. Didn’t bother posting it because the orange can is going bye-bye…
You put the leaf spring on the top instead of the bottom of the filter.
Yeah, on a filter with fiber end caps the leaf spring needs to be put back in the exact location it was in (the impression it left) before it was cut open.
  • Like
Reactions: GW.
That leaf spring looks pretty smooth. Date code is the 47th day of 2023.
The metal end cap E-Core version of this model was way better than the classic fiber end cap one. I would not trust it either.
