Fram FE7317 Endurance - new batch April 2025
NoVA
I picked 2 of these same date as other two failed FE3600 n my other thread
But quality feels and looks different
Dated April 2025
Seems new design of the relief valve plate and has plastic core, no metal core with louvers anymore
I am struggling to decide to keep or return based sour taste after FE3600.
X-ray needed to conduct the flashlight test :)
On their way out... if you feel like "one last run" is worth it to you. w/o doing a flashlight test or x-ray like you mentioned probably easy to say it'll have light. Overall, the rest of it looks good & I like the ecore swap.
Dated April 2025
Regarding Fram - I've completely lost trust in the company. They have lost their way. Their quality assurance is terrible. The constant cheapening of the filter materials and construction. The lack of regard for quality workmanship and the end user.
I wouldn't want to risk engine damage by using any filter made by First Brands / Fram.
FE Ecore been discussed before in the 7317 application, linked. There, initially Champ Labs baseplate was focus but eventually OP gets to saying it's an Ecore. Won't repeat my comments except to say in my observation, Champ Labs bypass piece seal area design same whether louvered tube or ecore.
https://bobistheoilguy.com/forums/threads/fram-endurance-change.390137/
I like the comment that base plate, ecore, bypass, looks exactly like SuperTech one!
Is the endurance with encore just rebranded MP7317??? :unsure:
I did not have MP, but ST is very close looking of course shorter and natural rubber gasket - but construction very close
Considering the fact that the PG made filters are cheaper, more readily available and filter just as good if not better than a non leaking Endurance I just can’t see why anyone would want to go back to Fram again 🤔
I posted earlier, for the application (Nissan's V6 3.7) Fram XX7317 just a bigger filter designed for Nissan's V8 which fits V6
Everything is puny including PG for such a missive powerful engine.
.....Is the endurance with encore just rebranded MP7317??? :unsure:.....
Let's say an MP7317 with wire backed full synthetic media, instead of cellulose. Everything else pretty much the same. Both use silicone adbvs.
The MP7317 wasn't full synthetic media with wire backing. It might be constructed the same, but the media is Endurance specific.
Dated April 2025
Same general design as the K&N filters like the new 1010... not that great inside and the 1010 has no wire
Really thin adbv..
Is there an engineering reason why the plastic/ecore is not superior to a metal core with holes/louvers? It would seem to me that in addition to likely being cheaper to produce and equally structurally sound, it eliminates the potential for closed louvers.
Don't see why it would be "superior." As discussed very often here, it won't flow better than a metal core with holes or properly formed louvers. Equivalent, yes. As noted, the current Champ Labs seal area is the issue whether ecore or hole/louvered metal.
