Originally Posted By: SteveSRT8
Originally Posted By: driver123
The chevy 3.4 liter and 3.1 suffer from intake and head gasket troubles, mainly due to the dexcool debacle, these engines require intense maintenance of the cooling system. It's wise to flush the cooling system once a year
Let's all just flush the whole deathcool thing okay? Nothing wrong with the coolant, just the design and execution of the gasket and engine.
Dex is so 'bad' even Ford is using it.
I said basically the same thing earlier and driver123 pointed out that the gasket eating tendency of dexcool (2EHA) was a problem with the GM 60* V6. I would have to agree with him on that point and say that dexcool is not a great choice when the i-m gasket can lead to leakage into the oil (wet system) or when air can enter the system (sludge prone).
In a properly engineered system dexcool is an excellent choice, IMO
PS: When I replaced the i-m gasket on my Buick's 3.1 a couple of the bolts were barely more than handtight.......I stand by my statement that if GM used several more bolts along with permatex the problems would have been far less......I'd also add that had they used a non 2-EHA coolant the 3.1 would be known as one of GMs better engines (except for the piston slap which didn't seem to affect longevity).
