We as a community can’t in good faith call out M+H for torn media/closed louvers and not call out Fram/Champ for badly stamped leaf springs. That’s just playing favorites.
You see that's what official black & white "spec sheets" do. They weed out incorrect data & sales pitches. I've emailed several companies & have gotten wrong information before as many of this board has. I'll need to email them to ask but again...Customer Service is not always official responses w/some companies asterisk* terms.I have not come across public specification documents from fram for their filters. I dont think these documents are available for public. People however did email Fram endurance customer support (myself included) to inquire about 99% efficiency, it was somewhere 5-10um @99% (dont recall exact numbers).
Could fram customer support be telling lies? I guess anything is possible.
It can be discussed a million times, digging for something else, but those are the numbers they publish in writing today. That’s what it is.Its been discussed many times, the information on website does not match official specs provided by manufacturer of PLB. The specs are provided in this or other thread, you can also request them directly from manufacturer
You really could cut the 20-25k mile filter longevity claim in half and still get 2 uses (5k OCIs) out of it.I hadn't bought a Fram oil filter in 20+ years, but all the Fram Endurance talk got to me. I ordered 3 of them through Walmart for my 2021 Equinox 1.5T. I have to say it's got the most weight to it that I I've felt in this size of filter. The baseplate is super thick. The can feels very thick. It's a pretty filter. Are ~$12 oil filters really worth it? That is a first for me. I'm not going to run them for more than 4-5K miles in this turbo GDI engine.
View attachment 223388View attachment 223389
Beat me to itCertainly not if you're going to waste them on such a short interval, turbo GDI or not.
On the XG2 made in summer 2024 I cut open it was also the dirt and the end cap no longer has the protrusions on the base end. Both end caps are now the same, $ saving. When they drop the element into the can, cross fingers it lands in the center, there is no sideways protection from movement. The adbv does not sit in a recess. It lays on a dome where the base holes are. So it’s more than one strike for me, it was three.We as a community can’t in good faith call out M+H for torn media/closed louvers and not call out Fram/Champ for badly stamped leaf springs. That’s just playing favorites.
Any filter with an efficiency of 99% @ 46u, regardless of brand, is a "rock catcher" to those that focus on filter efficiency. Has nothing to do with the efficiency of other filters.The Boss is 46um @99% & that is a fact from the spec sheets. You made the bold claim that Boss was a "Rock catcher" w/o knowing specific filter data from Fram?
As verified by the vaunted, official, black-and-white data sheet.Any filter with an efficiency of 99% @ 46u, regardless of brand, is a "rock catcher" to those that focus on filter efficiency. Has nothing to do with the efficiency of other filters.
That's what Purolator should consider when their website efficiency claim for the referenced Boss doesn't match the official spec sheet for the same filter model.You see that's what official black & white "spec sheets" do. They weed out incorrect data & sales pitches.
The M+H official spec sheets reference efficiency test spec ISO 4548-12. The BR efficiency test is not any kind of official test standard, and doesn't use calibrated real time up stream and down stream particle counters. It's a good attempt of a home made test, but not official except for the PC testing they send out. It's funny how YT creators become the new test specs source that somehow "proves" that world wide used test specs are invalid and over-ridden.Given the data from BR I think people should be open to the possibility that the Boss filter spec sheet is erroneous.
You must know what is not a "rock catcher" before knowing what a rock catcher is. It has everything to do with how it "Compares" to similar filters on the market.Any filter with an efficiency of 99% @ 46u, regardless of brand, is a "rock catcher" to those that focus on filter efficiency. Has nothing to do with the efficiency of other filters.
Yes, I agree & right along w/Fram that does the same. Referencing folks that have emailed Fram & gotten a worse efficiency response when that filter on their website advertises 95-99% At 20.That's what Purolator should consider when their website efficiency claim for the referenced Boss doesn't match the official spec sheet for the same filter model.
The word means different things to different people. I mean you tend to make up your own definition of words.You must know what is not a "rock catcher" before knowing what a rock catcher is. It has everything to do with how it "Compares" to similar filters on the market.
I mentioned it may be that Boss rated as it did in the BR testing because the Fram and RP (Champ made filters) had leaky leaf springs, thereby reducing their efficiency in the same ballpark as the Boss. The Boss was obviously much less efficient in the official ISO 4548-12 test done by Ascent.I’d bet the Boss is more efficient than a Fram or Champ with gaps in the leaf spring.
Absolutely possible.I mentioned it may be that Boss rated as it did in the BR testing because the Fram and RP (Champ made filters) had leaky leaf springs, thereby reducing their efficiency in the same ballpark as the Boss. The Boss was obviously much less efficient in the official ISO 4548-12 test done by Ascent.
See post 222 ---> LINK
