I'm running my 3.0L V6 Ranger truck with it's first tank of gas that has a double dose of FP included. I'll use the normal dosage after this one.
This truck has always had a pinging problem and some of it may be due to carbon buildup. If I keep on using the FP regularly, how long would you guess it would take for the combustion chambers and pistons to get cleaned up? Or do I have to remove the plugs and do the LC cleanup routine?
I'm just trying to eliminate possibilities before I do anything major. I've already done basic stuff like clean the MAF, change spark plugs, replace the PCV, etc.
