I've got a fillable form that I fill out in FoxitReader, but when I try to print it, those fields where the text was entered show up as empty.
Tried searching for a solution, but wasn't able to find anything. The solution I found on foxit support forum was to install an older version of FoxitReader, which I did, but the problem persists. Tried on two different machines (one running XP Prof, the other - Vista Home Premium) - same problem.
Any of you come across a similar problem?
