Found this info. What do you think.
Australia
From Lube-tips
Q & A
Switch to Synthetics?
"I am considering replacing the mineral oil in my engine with a synthetic oil. The engine has 50,000 miles on it. I have heard that the mineral oil and synthetic oil are compatible. Is this true?"
Generally, the reference to synthetic oil for an engine, means a lubricant is formulated with a polyalphaolefin (PAO) base oil. PAO, which is often called synthesized hydrocarbon, is pure and is compatible with mineral base oils.
However, because the PAO base oil does not dissolve additives effectively, it is usually formulated with an ester co-base (usually di-ester and/or polyol ester). The additives are soluble with the ester and the ester is soluble with the PAO.
Likewise, the PAO tends to cause seal shrinkage and the ester causes seal swelling, so the effects are offset when both base oils are present. It is the ester that can cause problems when one changes from mineral to synthetic. Ester base oil used alongside PAO base oil in lubricant formulation has excellent natural detergency. In other words, it will clean up varnish on component surfaces as a result of thermal and oxidative degradation of the lubricant. When one switches from a typical mineral-based engine oil to a typical synthetic-based oil, the varnish layer will be removed by the ester in the synthetic oil and become suspended.
This suspended material can rapidly clog filters and can block oil flow passageways and lead to component starvation. The same is true for gearboxes and other industrial machines. So think twice about switching to synthetic oils in applications where the engine or other machine has been operating for some time with mineral oils. If you decide to make the switch, try to clean the system before making the change, then monitor it carefully once you start it up.
Yeah, this has been posted quite a few times. I wish that I could find this miracle synthetic that rapidly clogs filters.
Until then, the closest I've found is arx.
I agree with this 100%. My honda was changed over at 115,000 and without auto-rx I am sure I would have had problems. Lots of gunk,stuff came out of the two auto-rx flushes.
I'm not doubting 100k miles of driving builds deposits. I'm doubting the ability of a synthetic oil to remove the deposits. Arx will do it, anything else, not so much. I still haven't seen much photographic evidence to the contrary of synthetic "cleaning" an engine. I've seen plenty of synthetic KEEPING an engine clean, but as far as synthetic oil alone removing deposits quickly enough to clog a filter.....HA!
I tried it myself with the king of the "cleaner oils," Redline. 5,500 highway miles saw no photographic difference. That's just me and my deposits are stubborn but you just don't see synthetic cleaning up sludgers left and right.
