Forney Easy Weld 251 20 P Plasma Cutter, uses?
GON
$175 Site Donor 2026
White Sands, NM
About three years ago, I purchased a Forney Easy Weld 251 20 P Plasma Cutter, at a deep clearance discount (about $240), at Tractor Supply.
The plasma cutter is still in the box, made the purchase because of the price.
What the heck does a plasma cutter do?
Used by serious autobody guys and artists around the world for cutting sheet metal. Also works on heavy guage metals but process takes longer.
  • Helpful
Reactions: GON
A plasma essentially uses ionized air to cut steel. They've also found ways to cut other materials that are not metal but I've researched that zero.
It's a hand-held Etch-A-Sketch for metal. Very versatile, good access to the work, and will show every tiny bobble in your cut. A fence is mandatory if you wanna cut a straight line.
Consumables like tips, electrodes and nozzles can be very costly if cutting a lot and/or using poor technique.
TL;DR: it's a fancy O/A torch (with the benefit of being able to reasonably cut aluminum)
  • Helpful
Reactions: GON
