So hopefully I don't confuse too many people here with these numbers. I've recently been purchasing my engine oil from Costco Canada Warehouses. Cost is $2.50 per liter (quart) which is the most affordable I have found anywhere. So, after some research, found that it's a mineral oil blend, though Shell does produce both Synthetic and Synthetic blend oils.
After extensive digging, I found this document ( Shell Canada Technical Document
What confuses me, specifically, is the chart on pg. 32, detailing several key specifics from their oils. Looking at the 5w30, NON-synthetic blend (4th column), at the Cold Cranking Simulator (CCS) and pumping viscosity, what units are they in? While comparing the numbers to Shell's 100% synthetic, it seems to indicate that lower is better, but on what sort of scale? Is it similar to the viscosity index, where while it is higher, a difference of 13 is not excessive enough to lead that there is significant differences (5w30 mineral= 154, Synthetic 167).
Thus, the full question is, based on the data from the document provided by Shell, how significant is the differences between the 100% synthetic, the synthetic blend, and the mineral oils based on their viscosity at cold temperatures, their cold cranking simulator, and their viscosity index?
Any help would be much appreciated.
