Since it has been getting cold at night here (ok, not REALLY cold, but cold for GA) I've been noticing that FordPass has been reporting the truck is going into 'Deep Sleep' which disables remote start and unlock features. The truck is only supposed to do that when it sits longer than 14 days or with low bettery voltage.
Sure enough, after a 12 hour sit, battery voltage was showing 11.8 volts, which is pretty low for an AGM battery that shouldn't be much more than a year old, on a truck that has Auto Stop/Start disabled.
Took it to the dealer, waited 2 hours and left with a new battery. No muss, no fuss, although they did say that after putting it on their 'battery machine' it tested fine, but they replaced it anyways. Not sure about that, but the truck doesn't go to sleep anymore overnight.
Just a tidbit for you if you have a Ford product that supports FordPass and you notice the vehicle going to sleep after sitting for a while. Have your battery checked, you might have one on the way out.
