Ford Specialty Coolant and Hoses
North Texas
I have a multi-part question i am hoping someone can lend me their expert opinion on...
I have a 2001 Mazda 626 with the 2.5 liter V6. I believe Ford/Mazda calls for "Ford Specialty Orange Coolant # WSS-M97B44D".
My question is, is this nothing more than Dexcool? Or is it another formulation?
My second question is regarding Radiator Hose life-span. My 2001 has 53,000 miles on it. Hoses still are all original and look to be in excellent shape. Should i replace ALL the hoses (including heater hoses) now? Replace none now? Or perhaps replace just the 2 main radiator hoses for now and keep my eye on the rest?
Car is in excellent shape, no cooling or engine problems or leaks at all.
I had thought i'd keep with whatever came in the car, but upon reading more and more on Dexcool i'm thinking perhaps a change over to G-05 coolant might be a decent idea. Are G-05 and Dexcool ok to mix if there is a small amount of Dex left in the heater core?
I would assume plain old green anti-freeze is safe to mix with almost anything.
I think 10 years/100,000 miles on hoses is fair, just keep an eye on them to make sure they are not cracking or dry-rotted.
As for coolant, Prestone All Makes/All Models may be all you need. I think the orange coolant you're referring to is Dex-Cool, as Ford began using Dex-Cool in the late 90's, if I recall correctly.
I'm pretty sure the only car Ford ever put Dex-Cool in was the short-lived Mercury Cougar. Ford went directly from green to G-05 in everything else.
Thanks for the responses. This is a Mazda, with a Mazda Japan built engine, however the car was assembled in Michigan, so who knows what they used. The orig coolant was orange/red (I'm partially color blind which does not help). I had it flushed once at the dealer and they used the above mentioned "Ford Special Orange" which appears to be something other than Fords regular "red" coolant.
It was a lot easier when everything was green!
Prestone All Makes All Models
Actually, specialty orange is DexCool. Premium Gold is G-05. Green snot is green snot.
The Cougar was assembled in Flat Rock, Michigan.
Prestone® Extended Life 5/150 Antifreeze/Coolant meets or exceeds the following industry standards and specifications:
GM 6277M
Ford WSS-M97B44-D
Also a lot of Dex-Cool products meet this WSS-M97B44-D specification so I do believe it is a Dex-Cool formulation.
Thanks! So far i've not had any problems so i may stick with dexcool since thats what's been used thus far.
We basically use Specialty Orange as Dex in my Ford shop.
Not used in much. Can't say I have ever noticed it in a car and parts yells (Kidding really) at me all the time for the amount of coolant, Mercon, Smurf Juice I use topping of the fluids.
