1998 ford ranger with almost 230k. Vehicle is daily driven. I dont know if this is an issue or if its just the way its programmed. When the vehicle is warm and under light to medium throttle it shift from 1-2 around 2500-3k rpm but then stays in 2nd for no time before shifting into 3rd. When the vehicle is first started and its cold it shifts like you would expect with 1-2-3 being of equal time in each gear. The transmission shifts beautifully and i keep up on the filter and fluid changes with mercon v. The valve body gasket was also changed a few years ago as they have a tendency to blow out. Is the quick second gear a normal fuel efficiency programming in the ecm or may there be some issue?
