Ford Fusion front end squeak/clunk
Rochester, MI, US, World
Our Fusion has developed a squeak (and clunk sometimes) in the passenger's side front wheel area. When making low-speed maneuvers, or if I just rock the wheel back and forth while still, I hear a squeak coming from that area. Truthfully, it sounds like a bad ball joint. So I pull the wheel off and inspect all boots and connections, and everything looks good, All joints are also nice and tight. Oddly enough, rocking the wheel back and forth while the wheel is off the ground DOES NOT create the noise; so the noise is dependent on load being on that corner. The only thing I could find, potentially, is that the sway bar link on that side moves quite easily. There is no play, and the boots are in good shape, but I can swivel it quite easily. The other side (which does not make noise), can also be swiveled, but it is tighter. I also hear an occasional clunk at low speeds when going over bumps; I assume these problems are related, since they both started on the same day. The squeak also occurs over bumps Any ideas? My old Focus had bad sway bar links which also had no play while installed in the car, but once they came out they flopped around like mad.
FWIW, the sway bar links on the front end are the dual ball joint type, not the bushing type or bolt pass-through type.
Originally Posted By: Klutch9
You guys awake this weekend?
I read your post but was waiting for someone to provide a better answer than I can. What I do with front end noises is I take the car to my favorite frame and wheel specialty shop where I get my alignments done and pay them a diagnostic fee to find the problem. Then I go home and change the part.
We don't see a ton of problems with those Fusions as far as the suspension. We have replaced a few of the front uprights since there are bushings installed in them that the control arms go through.
