The 3.0TT was originally developed for the now defunct Lincoln Continental (2017–2020). It was an exclusive engine until the Lincoln Continental tanked. Since then the engine is used across Ford and Lincoln performance models.
Guess I’m glad I have my two 2.7’s. Zero problems but I’ve only got 5 years and 85k between the two of them. Has anyone addressed the most important question of all time in the history of engine design choices (if to which the answer is yes then engine is trash) in regard to the 3.0 yet? Does it have a wet belt oil pump?
I replaced my 2017 NA3.5L 6speed F150 with a 2024 Ecoboost 3,5. I want my 2017 back. It was a simple truck overall, having less tech, and it idled smooth. The tech in the 2024 is flighty, choosing to lock up at times, and the 3.5 idles rough.
I’ve had the 2.7 before as well. It was hard to distinguish it from a 3.5 Ecoboost, even when towing. It’s an all around great engine.
If there was a good alternative to Ford, I’d be switching. The new models aren’t good.
Maybe RAM, but the rust issue alone keeps me away from them.
My guess is it just comes down to dollars and cents and between the different block materials and GDI/PI etc, the 3.0 is cheaper to make while getting them close enough in terms of specs.
I'd love to see Ford significantly reduce its engine offerings.
Reduced engine offerings have many seeds of equivalent benefits:
technicians get more time becoming SMEs
parts are easier and less costly to stock
promotes more clear engineering- engineers have less challenges to solve
One could go on and on for the list of benefits by offering less engines. I always cringed when the Lincoln Continental returned to market last decade. Numerous powerplant options that were forced into a too small engine bay. No way a tech was going to be fluent and/ or desiring to service a Continental. Same with the seat choices, a bunch of options and I am sure the parts for the Continental seats are no longer available. Ford should have picked on rock solid strong performing powerplant for the Continental, same with the interior seats.
No pun intended- buy makes one wonder who is behind the wheel making these decisions at Ford to offer so many options, when instead people likely prefer reliability.
