Ford 6F50 3-4 and 4-5 shift flare
Iowa
I've got a gal who had a used transmission installed out of state and by the time she got back home the axle shaft seal was leaking. She brought it to me and I fixed the leak with a new seal but on the road test I noticed a 3-4 and 4-5 shift flare. At first I thought that it might have been related to the battery being disconnected (I replaced the starter too) but after talking with her she said that it did this from the get-go after picking it up.
Is this a common problem, ie hard parts type failure, or is this something that can be addressed with a learn or programming change? My scan tool will reset adaptives but I don't believe that it can initiate any learns for it.
Do you still have the vehicle ? If so, put the transmission in Sport mode and go drive it. Is the flare(s) gone ? We had a Fusion with a 6F35 and a flare between 1-2 or 2-3 (one or the other, not both - I don't remember now) was pretty normal (common). When it sport mode though, it was non-existent. In my mind, that's an ECU or TCM issue, not a physical or mechanical one.
It's just as likely a valve body issue. Leaking, sticking, worn pistons and bores in the valve body that the rebuilder did not adequately address are common after rebuilds. Here is a chart from the Sonnax website.
https://www.sonnax.com/tech_resources/491-ford-6f50-6f55-vacuum-test-guide
If so, put the transmissionmission in Sport mode and go drive it.
I did the same thing with the 4R75W transmissionmission on my car, I always drove around with the transmission in Overdrive, and the transmission was kind of shifting gears and there was no get up and go. I turned off the overdrive, and the car was more responsive, I would only hit the overdrive button if I was cruising above 50 mph. I am cruising on a country road at 50 mph, and the rpms are a bit over 2000 rpms and what is amazing is my gas mileage was the pretty much the same as when I had the transmissionmission in overdrive. These Ford transmissionmissions seem to only like overdrive when you are out on the highway and you are going more than 50 mph. With the transmission out of overdrive, I feel like I have 50 more Horsepower, maybe 30!
Now when I did have the car in overdrive and I wanted to really hit the gas pedal, I did take the transmission out of overdrive. Around town driving and below 50 mph or 2000 rpm's keep a Ford Transmission out of Overdrive!
Nice thought, but this is in a Taurus wagon and it doesn't have a sport mode that I can find.
Haha, probably not ! Well, you could replicate it with your right foot. Just do some very hard acceleration runs to change the shift points.
It definitely doesn't like increased throttle inputs.. the shift flare gets noticeably worse with throttle and RPM.
The Solenoid Strategy Code & Solenoid Body ID Code has the be programmed anytime the transmission and/or solenoid body is swapped, This can be done with Forscan.
Look for a tag with the codes on it on the transmission case.
Now that is some great news! Do you know if just the basic, free version will do it, or do I need the paid for version?
Well I think that I'm hosed on the deal... I have the most current version of Forscan that publicly available (2.3.71) and it won't perform the Transmission Characterization Update. It says that there is a TRID block integrated into the firmware and that version 2.4 or higher is required. Unfortunately all links to versions higher than 2.3.71 are dead.
Do you have any more input on this before I boot it out the door to the dealer?
There are mobile outfits that program at your shop. Ford & GM programming is pretty straight forward with a J-box but requires an investment in tooling & schooling
Ill keep my eyes open for a used one - I don't have much call for programming at the moment so it's hard to justify the expense.
Thank you for taking the time to help out, it is appreciated!
