Ford 4.6L Coolant Pressure Mystery
Central Oklahoma
I'm looking for an answer to an almost 2 year old question about my '03 Marquis. I am going to link another thread that gives some unrelated yet possibly relevant info about this car at the bottom of this post. But the issue at hand is a strange one. It's two years now because I've had the mindset of "if it ain't broke, don't fix it." But I now want the fix and peace of mind...
The car has been running very well for the last 2 years I've maintained it (5 months owning it). In two years, it has NEVER been hot on the gauge. I've even driven 600 miles one-way in one day. But before and after changing the intake manifold, thermostat, radiator cap (Motorcraft), and a coolant flush, the coolant will NOT build pressure. I can literally run it 600 miles/10 hours straight, pop the hood, and take off the radiator cap very quickly. I'll barely get a wheeze, much less a hiss. But again, no overheating either. There's no evidence of weeping, and definitely no coolant loss at all. And I have pressure tested the system, no problems there either.
My initial thought was thermostat, of course, but this is the second one and still nothing. Surely it's not clogged anywhere because that would definitely cause an overheat. And a stuck thermostat makes no sense open or closed, because the car warms to normal temp quickly as it should.
So what could possibly be the culprit here?!? My only wild guess (thanks to a trusted mechanic) is the water pump, but we both agreed it's extremely slim odds. I'll be changing the pump this week, just to eliminate the variable. And I refuse to accept a counter jockey's answer of "it won't build pressure because the cap is on the expansion tank." So what's the point of the pressurized cap then?!? It HAS to build pressure. But if the water pump doesn't solve it, I'm going to lose my mind. And I know, it sounds literally impossible, and even I doubt my evidence/facts, but it's the truth. I swear!
HUGE thanks in advance for help!
Unrelated Yet Relevant Info Link
That cap on the resesvoir should be checked, that tank is pressurized on your G.M.. Don't waste your time with the water pump unless it's weeping. Listen to your counter jockey, it's a cheap part compared to the water pump.Face it, your have a leak somewhere, bleeding off the pressure.
The cap... The initial cap was bad. So I bought a Motorcraft replacement. When I still suspected it, I exchanged it for a THIRD Motorcraft cap. It's not the cap unless I hit the unlucky lotto of 3 bad ones in a row.
Agreed on the pump, but $30 for a brand new (not reman) replacement pump with a lifetime warranty was a no-brainer. And pumps on these are a breeze to change, so why not roll the dice?
And I can 100% assure you there is no coolant leak anywhere. I've kept track of the coolant level (even marking it). It hasn't moved a millimeter in 2 years. Nothing in the oil, nothing on the driveway. Nothing dripping down the motor (just changed the oil again 2 days ago). Not sure what leak I'm facing...?
Perhaps you're referring to an air leak? I feel I disproved that by pressure testing the system. It held within 1 p.s.i. for 45 minutes.
I sincerely appreciate your input. However, I still think the problem is elsewhere.
What you're describing is normal.
Also, how could the water pump cause this? And how could the car run perfectly with a bad water pump?
Agreed, to a point. A water pump surely is NOT the culprit, but I've changed virtually everything else. For $30, I'll take an unnecessary shot in the dark. The factory pump has served 125k already. Why not?
But I'm confused how a pressurized cap on an expansion tank without any pressure building in it is normal...?
My guess is that somewhere, a the top of the system, air is allowed to escape. You very likely have a healthy cooling system and engine. The pressure builds due to expansion of the water (and air) in the system when hot. If the cooling system is not being taxed, a small air leak will prevent pressure buildup. The existing coolant will expand a bit and all will be well.
Also, if your hoses are really soft, they could expand a bit and reduce system pressure. But not likely to create a zero pressure condition.
Try bleeding all air from the system and see where the leak is.
the 1 psi pressure test performed above is not adequate. 14-15 psi is probably a better test. I'd test it at whatever pressure the oem pressure cap is rated at.
My S60 has very soft hoses. They all do. And it uses a sealed system where the reservoir itself is pressurized and has the bit of air stored in the top of it too. But when it's at temp, all of the hoses are rock hard. I would expect the same in the 4.6.
You have a tiny leak somewhere, but you are not straining the cooling system enough to start boiling fluid.
-m
I recently changed the intake manifold on the F350 and there are a few ports on the coolant crossover that can be opened up (either for the various temp sensors or maybe bleeding), is it possible that you are losing some coolant and air through that?
Or have you checked the coolant bottle itself? There could be a hairline crack in the seem that you are not seeing.
Originally Posted By: HoosierJeeper
I'd replace the cap.
Or at minimum test the old one.
I have twice already. I mentioned it earlier in this thread.
Thanks for actually reading and giving your input. I'll replace the hoses too (not much to lose at this point), but I highly doubt there is air trapped. It's had the coolant flushed at a shop (prior to owning it myself) and it's had 2 years since then to burp. I've never had this much difficulty with coolant. Usually it's very black and white.
Originally Posted By: Trav
Start by testing the cap and pressure testing the system, this is a very easy issue to diagnose.
I have already stated earlier in this thread that I did. 3rd cap and pressure test passed...
-m
You misunderstood, but I didn't exactly clarify. It lost less than / stayed within 1 p.s.i. over 45 minutes of pressure testing. The cap is rated at 16 p.s.i. and that's the pressure it was tested at.
Thanks for the input. I'm not sure, I'll have to look later as it's not the factory intake. It's a Dorman replacement (working well btw).
As for the tank, I have looked many times (but never with it out of the car, so I may overlook one every time). However visual inspection aside, if it lost less than 1 p.s.i. over a 45 minute pressure test, I highly doubt there is a leak.
I'd go over the car with an Infra Red gun. If you have normal coolant, trans, and engine temps everywhere, I'd leave it all alone....until another symptom shows up. Most people would be quite happy with normal coolant temps, especially on hot summer days. There are numerous places where a slight weep could cause pressure to leak off undetected. A drop test of the coolant system might not even find it. I recently had a slight transmission fluid cooler leak into my coolant system. Droplets of oil were showing up at the top of the coolant reservoir. Yet a 24 hr coolant system pressure test showed nothing.
No leaks, normal coolant temps and level, never overheats. Sounds good to me.
-m
Yes, I misunderstood. So it holds pressure, shows no leaks, yet doesn't pressurize. Was the pressure test done when good and hot? Now I see why you are stumped.
1. thought one: engine is not actually approaching full op temp. can you verify temp? IR gun? multimeter with a temp probe? This happened to me with chrysler 3.3 - t-stat was opening too soon.
2. thought two: pressure is only leaking at op temps/under load - such as head gasket or something with the intake manifold/gasket.
This is a good one.
m
Sorry it was early and I missed it. You could put dye in the system but as you said there is no coolant loss and its holding pressure and so is the cap. I suspect it might be normal. I have a VW with a totally rebuilt cooling system that act similar to this.
Here is a little twist to pressure testing, get a vacuum fill tool. Drain as much coolant as you can the put the system under a vacuum with the tool if it holds a vacuum for 30 sec-1 min with no significant loss of vacuum there is no air ingress.
The tool will allow you to refill the system with no voids for an air bubble to form. I use this one but there are cheaper ones that work fine.
http://www.tooltopia.com/uview-550000.as...CFdaFswodWroDQw
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjG4-Tv4KnUAhVMBBoKHTHYClAQFggtMAE&url=http%3A%2F%2Fwww.uview.com%2Fsite%2Fywd_uview%2Fassets%2Fpdf%2F99080802_airlift_ii_inst.pdf&usg=AFQjCNHE2rJCFCRWFeIY6n4ErJFv2eWlQQ&sig2=HhwX0MOeMJnKx8rQdj3UtQ&cad=rja
What temperature is the engine actually running? I couldnt care less what the dummy gauge on the dash says, Im interested in real temperature in degrees. Ive seen one of these cars with a lazy thermostat that ran in the 170-180F range.
Driving highway these things don't get hot unless you're pulling a big hill. 194F is where mine sits though I have seen 212 coming up a few big hills.
If you leave it idling with the Climate control on, it also won't get very hot since the fan is on all the time; mine will stay right at 194F on all but the hottest days. If you turn the climate control off and idle it, the fan will stay off until 210F or so.
