For those who like idea of Fumoto but don’t like the risk… try this!
The land of USA-made Subies!
Here’s some pics of my new Stahlbus drain valve. There’s no way for oil to leak from this unintentionally. Not only is the main valve a ball-check, there is a 2nd cap that’s sealed with o-ring. There is a small, 1/4 turn insert that’s attached to a chunk of hose to aid clean drains.
I’m actually thinking about attaching my vacuum extractor to the hose so I make sure I get a complete drain by being able to put the whole engine under vacuum 😎
The CleanOil is more than double the Stahlbus cost. The ValvoMax is close in cost but has a full thread to drain, whereas the Stahlbus is $46 and 1/4 turn. Like I said, I’ve used at least 3 Fumotos, and looking at all these designs, so far the Stahlbus is the simplest, safest, and easy to use drain I’ve found.
I already ordered one for the Transit Connect and will get one for my Impreza as soon as I find the right thread size. It should make changes on the Impreza about a 3-5 minute affair with no real mess!
I spent the cake for something like this for the 2.7 F150. The I/D for the drain hose was maybe 1/4”, which meant the I/D for the nipple inside the drain hose was even smaller. The flow rate was really slow, so I pulled it out, stuck it in a baggie and went back to the plastic yellow drain plug. their pan is such a unique design, most folks don’t make a solution for that vehicle.
The Fumoto is risky ? I had’t heard.
Where is the data on that ? All the ones I’ve installed are sill functioning OK several years later. Is there an expiration date on their reliability ?
Z
Z, there are plenty of “safe” applications for Fumoto. I’m not saying anything bad against them; but say on a 7.3 Powerstroke, the valve is the lowest point on the truck. I’d never use one there… but the Stahlbus is a lower risk anywhere due to the ball-check and o-ringed cap. It requires the insert to open the ball-check and cannot be opened by road debris. That’s all…
While shopping oil drain valves, I came across Aeroquip sump drain valves for a Continental engine that was $409.00. Good thing the threads were 5/8-18 and wouldn't work any applications I have. There was another with 1-18 threads. This one was $1,264.00 :whistle:
$100 seems a bit high for what it is
It's also very nicely made. It's a nice system - with the extractor pump - I can see the attraction for a shop with lots of high end cars that have plastic engine shielding. The time savings alone from leaving the under pans in place would make this attractive.
