Originally Posted By: BlueOvalFitter
Originally Posted By: sayjac
I will say that while your pictures shows some substantial depth sealing gaskets, I've seen the PL/L14610 and with not nearly that much depth difference to the can edge. In fact, 'if' I had a nitpick about the PL14610 that might be it. Just sayin.
Ok, I can agree with you on that. But, do you think that tightening the filter too much might have caused this?
I just changed a PL20195 on my Tacoma, and the gasket on the used filter's gasket was smashed down pretty good compared to the new filter.
BOF - how long was that PureOne on your vehicle? Didn't you swap it out shortly after installing it. Mine was on for a year, so I think the longer it's on and the longer the OCI is, the more set the sealing gasket will become.
Z06, it had been on my engine from 7/9/13 to 9/18/13. The oil had over 4K miles on it. I recently changed it to use the PU 5W30 I just recently bought.
I find it hard to believe the gasket would compress more over time by itself. I can believe it will compress more if someone or something tightened the filter every now and then, or, over tightening it from the original application.
Maybe I am missing something here about the physics behind gasket compression and someone with more knowledge will chime in.
In my instance, the rubber base gasket on my PureOne did not spring back at all after the filter was removed - it was flattened pretty good. So if the used filter was removed and reinstalled, and you wanted to re-tighten it, you would have to go even tighter than it was originally to get a good seal. Now you might have to over-tighten the filter, which isn't a good thing.
Best thing to do if you are using an oil filter for more than one OCI is to not remove it ... leave it alone.
