A co-worker of mine has been bragging about how well Lucas Oil Stabilizer works in his transmission for the past couple of weeks. I showed him the test ran by Bob on this site, and he blew it off as being rigged by a salesman for another oil company. So I decided to do a little test. It was time to change my transmission fluid out anyways, so I replaced it with 75% Phillips SMP 80w90 (a good dino fluid I've used in the past), and 25% Lucas per Lucas' instructions.
We idled the car in neutral for 15 minutes, and then drained the transmission again. Here is what we found:
The quallity of the photo isn't the best, but the foam should be obvious. Both the SMP and Lucas are a light amber color that would have been hard to see in the black drain pan. The foam is almost white. When dumped into my 5gal. pail I use to store used oil for recycling, the majority that I dumped was this foam. Maybe 10% amber fluid.
He then asked me to change his transmission fluid this afternoon since I was already changing mine.
