Going to be dropping the pan on my 6r80 equipped F150 soon. This is a non-dipstick trans which has a fill port under the vehicle (very close to a cat). Using Maxlife ATF which seems to have a larger than normal mouth. Any suggestions for a fluid transfer pump? At this time, I'll probably use the $5 HF/parts store special and I also have a funnel with 3 feet of fairly small diameter tubing attached which might work. Both these methods will likely be slow and frustrating as it will take something like 6-7qts for a pan drop based on what I've seen online. Any better options out there without spending a ton of money?
I do have a motiv power bleeder which could be used but Motive recommends not to since you could end up with contaminated fluids. If I go this route, would a rinse and flush with isopropyl be adequate to decontaminate the unit before and after?
