Fluid recommendations for 1968 MGB
Well....I made a terrible financial decision and bought a British car! 🤣🤣 All joking aside I got it for $3500 and it runs very well. Few quirks, switches and things that need addressed all pretty easy stuff to fix it appears.
What fluids should I run in the rearend and in the transmission? Anything special? Any one know of a certain engine oil these like or prefer? Also seems that these can run unleaded? Should I be using a fuel additive? I know several questions in one post but I know so little about this car it causes a little anxiety. That all being said it's great fun! Thank you all for all the input and advice. 🙂
Welcome to the club...I'm sorry:D
I've had or still have several B's, Midgets, Spits, old Rovers....and two TR6's, and my go to mix is:
-M1 15w-50, IIRC you have the cartridge filter, so Crosland filters are prob your best bet...avoid 'white box' generics.
-Redline gear oils for the transmission and diff, usually MT90 and 75-90 (Redline gear oils are non-corrosive to yellow metals)
-Castrol or Ate Dot4 brake and clutch fluids
-Redline lead substitute (there was a British study a while back that determined that very few lead substitutes were actually effective, and Redline was the only one sold in the US) Consider a substitute if your car's head was never rebuilt and hardened seats installed. British iron heads are soft...
-MMO in the fuel only (NOT as a magic elixir for whatever, but its use was recommended to me years ago as a way to lessen corrosion in the ullage of the fuel tank; should leave an oily film above the 'water line'. Corrosion there was a problem w/ TR's)
I never had a problem w/ synthetics in 30+ years of playing w/ British and other old cars, but I will do one or two short duration oil changes if I suspect significant deposits in the engine.
Good luck, pics please.
I was pulling for the MGB in your last thread.
I hope you enjoy it. These cars are simple and easy to work on. There really isn't much to break and parts availability is good. The gauges are real and undamped, so you'll see constant little variations in oil pressure and coolant temperature, nothing to worry about but unlike what you see in modern cars. The electrics are a bit of a weak point, but OTOH there isn't much of them. You can have hydraulic issues, but repairs are not difficult.
This car would have an oil cooler, so any current 10W-40 would be fine for the engine. You can use the recommended 20W-50 but it really isn't necessary. I almost always used 10W-40 in mine.
WRT fuel, there are different schools of thought. I have read that for any engine designed around leaded fuel many hours of running hardens the valve seats simply by the valves peening them hard through countless closings against the seats. Maybe so. The BMC B-series is a good engine and was used in a wide variety of their vehicles.
Wow, looks good!
For $3500.00 this seems like a steal, especially since it's on wires. Anachronistic, but nice.
One other thing, make sure that you lower the prop rod when closing the boot lid. It doesn't disengage itself and this is why you used to see so many MGBs with minor bends to the left side of the lid.
Nice! I've been running Valvoline VR-1 20W-50 in my Midget, and that's what I use in the dashpot. I want to say I had put Valvoline 75w-90 GL-5 in the rear and the transmission. I had remembered reading something about GL-5 fluids not being compatible with brass synchros in some older British transmissions, but supposedly the 1500 gearbox doesn't have that problem.
Moss sells oil for the hydraulic lever shocks, although filling them is a pain. Might want to at least make sure they are still full. I ended up getting a syringe from a pet store for feeding baby animals, worked perfectly for putting oil in the little fill ports.
Congrats......the only thing that I can recommend is that you put a battery disconnect switch on it and use it when you have it in storage.
Lucas electrics have their quirks including letting the lighting leak out of the big box filled with acid......LOL.
Has one already for a battery drain the owner said it's had for a very long time 🤣🤣🤣
Just a heads up here, but Every vintage British car owner should have a genuine “ Lucas smoke kit” in their boot in case of an unexpected electrical breakdown. You will most likely have a tough time finding one in this day and time but be persistent and beware of the cheap kits you might find on EBay. The British car clubs might have an original OEM kit for sale, but I’m sure they are going to be very pricey. ;)
Gorgeous car! Based on your photos it's an absolute steal for what you paid. Chrome bumper MGBs, especially 60s ones, don't come around that cheap often anymore.
If you haven't already, join MGExperience. There's SO much knowledge there on these vehicles.
As said, these cars are simple, especially the older ones, and it's often kind of amazing/alarming at how well even a poor condition engine will run.
Yours looks to be a 68 or 69 based on the pillow dash and the old style vertical slat grille. These are fairly desireable years-pillow dash aside for 68 the cars got some nice changes from the factory(negative earth and an alternator, rather than positive earth/dynamo, plus have a pre-engaged starter and 4 sync transmission). They have minimal pollution gear(side note-I actually prefer the PCV set-up of these cars to what's on my 1970, and recently retrofitted this style).
For fluids, here's the general advice and/or what I'm running:
1. Engine oil-20W-50 unless you have a good reason otherwise. I've run Castol Edge 5W-50, but honestly the only benefit I really saw was better cold cranking at temperatures I wouldn't really drive the car anyway and it's expensive. Many people will say a high zinc oil due to the flat tappet valve train. I have hedged my bets and always done this(especially since I'm now running a new, higher lift cam) but in reality most -50 oils have enough ZDDP(around 800ppm) to keep these engines happy. I've been running Valvoline VR-1 for years(1200rpm ZDDP, the "ideal" level per some), but Castrol in the last few years has introduced a(sometimes hard to find) "Classic" oil with this same amount of ZDDP. If you want something lighter, 15W-40 diesel oil often isn't a terrible choice.
While I'm at it, I run an FL-1A filter(or equivalent). That's assuming your car has a spin-on adapter with the filter sitting upright. If yours is a 68, you may still have a cannister filter-this is a fine set-up except can be fiddly to not get to leak and the cannister filters aren't the easiest to find. In any case, assuming you're using a spin-on filter, the FL-1A fits fine and you have lots of choices plus tons of filter media. There are some threads on MG Experience about specific filters-some don't have threads formed exactly right and can damage the soft aluminum on the spin-on adapter(I think Wix filters have this issue, or at least use to) and others interally can foul on the standpipe and interfere with flow. I currently have a Baldwin on mine just because it's what I happened to have in the garage when I needed one, but Purolator/Motorcraft are fine and usually what I use.
2. The gearbox gets 20W-50 also. The 4 sync box is tough(aside from the 4th gear baulk ring liking to crack-you'll know this if yout transmission grinds shifting into 4th). It's not stressed a ton and you don't need wear additives. I've usually used Supertech brand at Wal-Mart, but really have just gone with whatever is cheap when I needed to fill.
The non-overdrive transmission isn't too picky. If it's an overdrive transmission, I'd suggest NOT deviating from the recommended oil. It depends on the proper hydraulic pressures to engage the overdrive(in the 400-420psi range). In fact, a first line diagnostic for a non-working OD is often draining and filling with 20W-50.
You should have a "top fill" transmission, which has a dipstick tucked behind the center console. Look for a rubber plug on top of the transmission tunnel. Once you get it out the first time, put a heavy zip tie or piece of wire around the dipstick handle as it will make future removal easier. This whole operation is MUCH easier from the passenger footwell. To fill, you will want a funnel with a long flexible spout, and be ready to still probably make a mess. Fortuantely this is not an operation you will need to do often.
3. GL-5 spec gear oil has issues with "yellow metals" and can cause issues with the thrust washers and other parts in the differential. I forget what brand I've used for GL-4 spec in the past-it was something I bought on Amazon. It's out there-you just have to search for it. The drain and fill plugs are I think a 7/16 square drive, but don't hold me to that. Most people, me included, take a cheap 1/2" extension and grind it down to fit.
Before changing the differential fluid, I'd suggest checking and changing the axle oil seals, especially as a leak there can potentially end up on your rear brakes and kill them pretty quickly.
4. Check your steering rack boots. Most originals are long gone, and the replacements are at best good for a couple of years. Yours are probably bad. Replace them(tie rod ends aren't a terrible idea while you're at it), and while you're up there be sure you grease the kingpins(3 nipples on each one). Repacking the front bearings is a good idea too if you don't know when it was last done(the front one had a bad tendency to go dry). The original Timken bearings rarely go bad(they are massively overspecced for the application-they're the same as what's used on 70s full size GM cars that way 2-3x what an MGB weights), and are much higher quality than anything you're likely to find for replacement, so I'd recommend saving those. I don't have any particular grease preference, and I don't think anyone else does either-just use whatever is in your grease gun.
Note that the steering rack gets oil, not grease, which is partiallly why the gaiter boots are so critical. John Twist has a good video on Youtube about filling the steering rack as well as some adjustments to make while you're servincing this. He also has a few on servicing the front hubs-note that they're NOT set up like a typical American car(where you tighten the nut until the hub seizes and then back off). Rather, you tighten to a specific torque, back off just enough to be able to put a split through the castle nut, and check for proper float(and adjust with shims if it's not correct). See again a few John Twist videos on this.
5. Change your brake and clutch fluid if you don't know when it was last done. Really fluid-DOT3, DOT4, DOT3/4, or whatever is fine. I'd suggest using a turkey baster to suck the old fluid out of the reservoir and then refilling. As long as the MC doesn't run dry, you can be lazy and just just crack open the bleeders until they run clear to finish flushing. On brakes, you want to go left rear, right rear, right front, left front in that order. Don't let the clutch run dry as the slave cylinder can be a royal pain to bleed.
While you're back there, adjust your rear brakes. Take the wheel off(I learned that one the hard way) and turn the adjuster 1/4 turn at a time with a 1/4" wrench (you should feel a "click" with each turn) until you can't turn the drum by hand, then back off 2 clicks. It's not a terrible idea to run the adjuster screw all the way out, all the way in, and then adjust-they like to seize(I do this once a year at least on my car). If you have any residual spongy pedal feeling or whatever after you've changed the fluid and bled any potential residual air, usually adjusting the rear brakes will take that up.
BTW, watch for brake fluid leaks at the pressure differential warning activator(PDWA) valve(located on the left front fender ahead of the master cylinder-should have a big white electrical plug in the center). This is something a problematic and often misunderstood part-it has a shuttle valve in the center meant to light up the light to the left of the steering wheel on the dash if a pressure difference exists between the front and rear brakes, but it can leak, cause "cross talk" between the two circuits, or even shut one of them off completely if not reset. Mine's been modified such that it's just a glorified brake line union block, but at minimum consider at some point soon ordering a rebuild kit for the shuttle valve.
6. If you have the original SU carburetors, don't forget they need oil too :) . 20W-50 engine oil works just great, and they don't take much.
If you don't have SU carbs, get them :) They really are an excellent carb, and IMO the best all around option for these cars. You'll want HS4s for your car. If you do have them, know that the throttle spindles are a common and problematic wear location, and unfortunately it's really difficult to rebush these properly yourself(and not worth the money to buy the tools for a single set). Joe Curto and a few of the other carb masters will do the rebush only and return to you(along with a rebuild kit if you request). If your car is a 68 it probably has fixed FX needles, and if a 69 it's PROBABLY biased AAE needles and poppet valve throttles. If the latter, put in solid disks. I've never been happier with how my car ran than since I converted from biased to fixed needles and put #5 needles in. That's getting into the weeds, though. If your car runs fine now, tune up the carbs(there again, Twist has some good videos on this) and let them be for now unless you have a reason to get into them.
7. There's one other oil I can think of-the Armstrong shocks. This fulid needs little attention unless it's leaking, which it rarely does(unless the shock's been overfilled). It's worth giving them some attention especially since yours are closing in on 60 years, but it's easiest to do off the car and if you're pulling them, it's not a bad idea to refresh the entire axle(bushings, droplinks, etc). There are expensive solutions out there for oil, but I bought 2 gallons of hydraulic oil at Rural King(I think it had "68" in the weight? I still have the jug and can check). It was dirt cheap and 2 gallons is probably enough the service all four shocks on a dozen cars.
8. Since you asked about gasoline-your car's engine would have had a compression ratio of 8.8:1 from the factory. This is considered a "high compression" engine in factory parlance(72 and later US market engines were 8.0:1) and is a nice compromise of power and being fairly tolerant of fuel. If you set the ignition timing correctly, you should have zero issues with 87 octane. BTW, I'd highly recommend getting a dial back light if you don't have one. The manual will tell you I think 12º BTDC static. John Twist says 32º BTDC at full mechanical advance(around 4K rpms), vacuum disconnected. I don't take that as a set in stone number(even though if you do a JT rolling tech session, that's where he'll set it) but it's a great starting point and most engines will really well there.
It's worth checking your distributor, though, as a lot are pretty tired now. With a dialback light, it's fairly easy to check. I THINK your car should have a 40916 distributor, the "good" one, which should advance 20º more or less linearly from 1K to 4K RPMs(or about 5º every 750rpms). Check your vac advance can-you can do a quick check by sucking on the hose and making sure it holds vacuum. To test operation, you can use a Mightyvac connected to it. Your distributor should have a 5-13-10 vac advance. This means it will start to advance at 5" mercury, be all in at 13" mecury, and give 20º advance at the crankshaft.
I can think of one parting thought-
When I first got my car, and I've had it almost a decade now(bought it October 2015), I was excited that you could nearly build a car out of the Moss catalog. I was pretty quickly disappointed that most of what's available is junk. I buy almost exclusively through Basil Adams, a reseller out of California, who has bunches of sources and can advise a lot on quality. I also am big on refurbing old parts or fitting NOS when I can(I have a few sources I often go to for these). For the big stuff in particular, like your distributor, you're 100x letting Jeff Schlemmer rebuild it than buying a new one.
Had a 1980 MGB for several years and used Castrol GTX 20w-50. Like ripcord said, if it's not leaking oil, ain't none in it! Fun car!
Not that a battery shut-off is ever a bad idea, but if it were mine I'd be looking for the cause of the phantom drain.
Key off, especially on the earlier ones(say pre-72 or so), there's almost nothing that should draw battery power. Yes there are circuits that aren't key switched(like the headlights) but when they're off, they're off.
If it has a radio, especially a newer one, look there.
Otherwise, really the only thing that's likely to cause phantom drain is a bad diode in the alternator.
If that's the case, you really SHOULD fix it for a few reasons, not the least of which is that it's probably hurting the alternator output when the car is running too. As kind of a quick and dirty diagnosis, watch the alternator light(yellow light) on the dash. It should turn on bright when you flip the key on but not running. The older 16ACR alternators(which is what your car would have had from the factory) will not often not excite until the engine hits ~1500rpms, so it's normal to need to "blip" the throttle for the light to go out, but once it's out it should stay out as long as the engine is running unless RPMs drop super low(it may flicker a bit around 400rpms, or basically if you're close to stalling). If the engine dies(key still on) the alternator light should come back on almost immediately.
If you see anything different from this behavior, including occasional flashes or anything other than completely off with the engine running and bright with the key on, engine not running, you have an alternator issue.
You can replace just the rectifier pack on the alternator, and that's not a bad option. You can also replace the alternator, and a higher output 18ACR from a later MGB is not a bad choice. Some people advocate using an AC Delco alternator(CS 130, sometimes called the "Saturn Alternator") although this isn't my first choice. Note, though, that your car likely has a "5 wire" alternator, and anything but an exact replacement will be a "3 wire." The conversion is relatively simple, but will need to be done.
Wow oh wow!
My first car was a 68 MGBGT. Pale yellow, wire wheels, the most beautiful aluminum-spoked real wood steering wheel. Back in the day, Hwy 2222 from N Austin to Hwy 620 was a great uncrowded underdeveloped windy curvy hwy to take the B out on in the middle of the night, or my friend’s Spitfire (we both liked the B better, but his was a convertible. From there, you could take Anderson Mill Rd, tighter, even less crowded, at 2:00am you’d be the only car on it…though you might have to share the road with deer or even cows. I blew the motor one morning going way too fast on some backroad north of Bryan TX; Dad graciously came and got me, towing the B behind his never-fails Plymouth Valiant slant six. We swapped in a 66 motor, a new clutch while we were in there, and life went on. Still an oil burner, but no further major failures. Dad bought an Opel GT, which was pretty lame in some ways compared to the B, but again was faster, more reliable. At one point Dad & I switched cars, giving me the more reliable car for driving to and from school in Austin to back home in Dallas once a month or so. He liked the B well enough, and had a not so tough commute to work, plus the back-up Valiant. He sold it for me for more than we paid (though the motor swap put us maybe $200 in the red for 5 years of usage (not counting gas, oil, and tires).
I had a couple of forgettable Japanese cars (butt-ugly Datsun 810, but at least a version of the Z motor and a stick shift, and the original Honda Accord), but after the BGT, my next car of interest was a 72 240z, and with some carefully chosen suspension upgrades I will maintain it was a TOTALLy better car than the BGT. Appropriately UT Orange made me acceptable to the Austin establishment despite my countercultural and after-midnight hwy terrorist tendencies. The Z was way more reliable, more powerful, handled well enough with the upgraded shocks, rack bushing, and sway bars etc. I remember how disappointing its handling was prior to the upgrades, but heh, there was a fix for that. Using all four lanes of 2222 (2 designated for each direction) to sweep through the curves at well over 100mph was great fun (illegal, irresponsible, dangerous) when the road was empty at 2am. If I recall, it also had a wooden steering wheel, though not as nice as the B’s. But, the Japanese copies of the SU carbs (or some sort of sidedraft) were set-and-forget, as opposed to the British SU which required constant fiddling. And it had A/C. 😂
From there, ventured into BMW’s (grey market 528i, a truly lovely classy car…silver with dark blue corduroy seats, small euro bumpers, followed by a 87 535i, better in most every way except looks, which, fast forward to today, I need to get rid of, as it’s been mostly just sitting for 10+ yrs. as I ventured into camper vans and the 07 turbo Subaru I’ve driven for those 10+ yrs). All stick shifts (except the vans). The 07 turbo Outback stick shift was a worthy successor, well at least after the suspension upgrades it required to not drive like a total pig. Lurking over turbo Subaru threads is how I got here: Orangepeel evidently has one, then I found he also has/had the MGB in this thread…which sent me waaay down memory lane. Sorry, just had to reminisce.
