Originally Posted By: punisher
If you are referring to the outer pad not retracting, then you have a point. If it was a problem however, we would see a lot more outer pad wear vs inner. Usually it is the opposite.
Sort of the point that I was getting at...it's not a problem in the vast majority of cases, in spite of the lack of elegance of the system.
