- Joined
- Oct 3, 2023
- Messages
- 549
This is a direct cross-reference to the Donaldson P551132 and indirect cross to the PH3614 which is spec'd for the Cummins B3.3 engine. One of the Fleetguard LF16011 arrived damaged so I decide to cut her open. Counted 53+1 pleats which includes the metal seam, probably the most packed synthetic media bought so far for such a small sized filter which I believe its their smallest Stratapore filter you can get that fits a 3/4-16 UNF thread. Endcap to endcap length is about 2.25" inches long, the whole outside filter canister measured 3.5 inches long. Unfortunately theres no micron rating other than a opaque efficiency rating of 100% at their website.
A Silicone ADBV is a nice addition compared to the Donaldson which has a black nitrile ADBV.
The bypass setting is a bit misleading on Fleetguard's website which says 28.6 PSI , the spring pressure feels slightly lighter than the Donaldson and Toyota, although those bypass face diameter is larger whereas the Fleetguard is smaller and similar to the STP XL one. The STP S3600XL has the most stiff spring pressure out of the rest. Kinda makes me say you can probably use it on a Toyota too, kinda odd its not listed as a compatible filter.
These aren't exactly cheap, probably the most expensive filter bought so far, they go about 20 dollars a piece, plus or minus a few dollars depending who you get it from. I'd probably go with the Donaldson since you get 2 for the price of 1 unless you need the silicone ADBV on the Fleetguard.
The only disappointing complaint I have about this filter is the center tube louvers are poorly formed on both samples purchased compared to the Donaldson. I expected better for a filter at this price range and big name in the trucking industry. Anyways Enjoy the pics.
Fleetguard LF16011
- Mewbs
- 33
Fleetguard's smallest Stratapore media filter for Cummins B3.3 - 53+1 Pleats. Direct crossref to...
