I have access to Fleetguard ES Compleat and it is recommended for gasoline engines by the manufacturer.
I was wondering how this compares to Dexcool and G05. It is a longlife coolant with OATs and it also apparently contains silicates so it would appear to be similar to G05.
http://www.cumminsfiltration.com/pdfs/product_lit/americas_brochures/LT15548.pdf
http://www.cumminsfiltration.com/pdfs/product_lit/americas_brochures/LT15070.pdf
An extended life, high performance,
that offers better liner pitting and corrosion
any other product on the market!ES Compleat
Maximum liner pitting protection using nitrite, molybdate and organic acids n Improved water pump life through low silicate and solids reductionn Best aluminum and solder protection through use of superior chemical buffersn Compatible with other coolants and SCAs for less concern
for contaminationn Lasts a lifetime, only need replacement in unusual circumstances
