I am doing extened OCI's on my 2004 F250 5.4, and am considering adding a magnet wrap to my FL400S filter. Any recommendations or comments? Thank you. Philip
But you'll find one in the oil pan of many automatic transmissions, and as part of some OEM drain plugs . . ..quote:
Originally posted by Ugly3:
Do you think there is a reason that no major filter manufacturer makes a filter with built in magnets?
For the filter company with orange filters that sells filters with Teflon in them, the only reason is because they aren't sure they will make money from magnets.quote:
If nothing else, It would have helped in the peace of mind stakes here.....quote:
Perhaps magnets are too expensive for a $3 filter? I'd say it can't hurt, but would there be any huge benefit?
Wrapping the magnets on the outside of the filter would trap it on the dirty side. I don't see a reason they would release, but it would probably only be a problem on filters with a dome end bypass.quote:
Originally posted by TallPaul:
The current issue of Noria's (site sponsor) Machinery Lubrication (may not be available on their website yet) has an article on magnetic filtration. One drawback is having a lot of metal bits collect in an area where they might later be released, such as where there might be pressure pulses, and clog something downstream. Another drawback is that the tiny metal bits could become magnetized and if they flow downstream can stick to critical metal parts.
All in all I don't like the idea of a filter magnet where pressure would pulse on the opening or closing of the bypass valve.
A magnetic drain plug is much safer IMO.
A true but meaningless statement unless the article went on to explain why that distinction mattered.quote:
The Machinery Lubrication article (Sept-Oct 05) states that "large ferromagnetic particles are disproportionately easier to separate from a fluid compared to smaller particles." This is because the magnetic force is proportional to the volume of the particle, but varies with the cube of the particle's diameter.
