FL300 motorcraft filter and 3.3 dodge
Pullman Wa
The cross reference for the standard PH16/ST16 for the motorcraft filter used to always say FL200, now it crosses to FL300 (which pretty much all walmarts stock) The FL300 looks exactly the same size as any of the standard dodge filters for the 3.3/3.8. Why the switch? I know that the FL200 and the standard FL1 will fit, is the FL300 the same diameter? Any help would be appreciated.
FL300 is a shorter FL1A
Here's how they break down in WIX
FL1A
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 270
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
FL300
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
Beta Ratio: 2/20=10/26
Burst Pressure-PSI: 275
Gasket Diameters
FL200 is considered the same as the FL300 as far as Wix is concerned. It's also not found on Donalson or Purolator and is the same as the FL300 in Baldwin
