Hello all...
I am trying to help a friend fix a tachometer on a 1983 Cutlass Supreme (which is in excellent shape otherwise). He recently had to replace an intake gasket, which required removal of the distributor. After reassembly, he found that the Tachometer would not return to 0 RPM correctly, depending on what state the ignition key was in. But, if the engine is running the tachometer seems OK.
As I am not an expert on this stuff, I was hoping someone may be able to offer some ideas on things to check out.
Thanks.
Thanks.
