I have these rust spots on my truck's roof around and about the clearance lights. They suck.
I've found my best results come from sand blasting the rust out. It gets the rust without removing metal thickness. If you keep rusting, and keep sanding, the metal will get mighty thin mighty quickly.
Throw away the dremel and sand by hand, young man. Put some elbow grease into it.
Then you mask, then you prime, then you take the tape off and go out another 1/16th", then mask/scuff/paint, then go out another 1/16th", then mask/scuff and clearcoat 2 times.
...for best results....
