Fixing Magnet to Plastic Drain Plug
South Wales, UK
So my daily has a plastic drain plug like this...
GM Part N° 55498782
The end of the plug is flat and I have a load of Neodymium magnets. I'd like to affix a magnet to the end of the drain plug.
I'm thinking of affixing the magnet to the plug with RTV. I suppose it wouldn't be a massive disaster if it fell off. It would either sit in the pan or get stuck to the pick-up.
Anyone able to come up with any better suggestions?
My suggestion is to not try and make a makeshift magnetic drain plug. Do you really want to risk something breaking loose and floating in the oil? And I don't mean the magnet, I mean chunks of the adhesive you choose.
I personally wouldn't have thought a pea-sized blob of RTV and a magnet would pose any kind of risk. But happy to be told otherwise :unsure:
I'd think you'd have to somehow capture the magnet rather than think an adhesive could hold it onto the drain plug. The other thing is how large a field will this magnet generate? I doubt it would be able to pull anything outside the first couple of inches and only when there's no flow.
Not that I'm aware of.
I believe this plug was fitted in a number of applications in the US but only in one application in Europe.
Drain plugs are often a standard M14x1.5 - but I see that yours has no threads, so assume the oil pan is likewise. Yikes, now I see the problem.
It's quite a nice plug to use actually. You pop a 3/8's extension bar or similar in, push up, turn it 1/4 of a turn and it just pulls out.
If you put the magnet, make sure you use a "High Temperature Resistant" magnet.
Otherwise, it will loose the magnetic power in the hot oil.
How long does the blue O-ring on this plug last?
My oil has been changed 4 times now and it's still sealing. I clean it thoroughly every time and apply a little fresh oil to the seal like I would a new filter.
I will replace it next OCI.
