first uoa
Alabama
hello all this is my first uoa with this car what do you guys think?
7
3
11
17
14
59
2245
8
659
806
4
12
4
8
1
61
37
12
8
2057
246
751
888
17
59
14
14
2245
8
1
3
We turned up a couple items of concern. First is sodium, which can show anti-freeze. It is also
used as an additive in a few different types of oil, though this type of Valvoline doesn't use it as far as we
know. If you used an oil that contained sodium in the past, then that could explain it. But we are also
concerned about lead and copper, which are typically from the bearings. Universal averages show normal
levels for these metals. The point is, you may have a little anti-freeze in your oil and it could be affect the
bearings. Watch your coolant level and your oil pressure.
05/05/08
01 INFINITI
Gasoline (Unleaded)
Valvoline Max-Life 5W/30
0 qts
5/13/2008
56-63
0.0
>365
11.11
420
0.0
0.3
44/284
9.1-11.3
63.2
Nissan 3.0L V-6
3,600 Miles
MAKE/MODEL:
FUEL TYPE:
ADDITIONAL INFO:
OIL TYPE & GRADE:
OIL USE INTERVAL:
MANGANESE
Sample Date
ALUMINUM
CHROMIUM
IRON
COPPER
LEAD
TIN
MOLYBDENUM
NICKEL
SILVER
TITANIUM
POTASSIUM
BORON
SILICON
SODIUM
CALCIUM
MAGNESIUM
PHOSPHORUS
ZINC
BARIUM
MI/HR on Oil
MI/HR on Unit UNIVERSAL
AVERAGES
UNIT /
LOCATION
AVERAGES
Make Up Oil Added
ELEMENTS IN PARTS PER MILLION
Values
Should Be*
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
©COPYRIGHT BLACKSTONE LABORATORIES 2007 LIABILITY LIMITED TO COST OF ANALYSIS
416 E. PETTIT AVE. FORT WAYNE, IN 46806 (260) 744-2380 http://www.blackstone-labs.com
PROPERTIES
cSt Viscosity @ 100°C
SUS Viscosity @ 210°F
Flashpoint in °F
Fuel %
Antifreeze %
Water %
Insolubles %
TBN
TAN
ISO Code
155,000
3,600
Maybe just forget this thread altogether, and start a new thread. This one can just be deleted.
Welcome to the forum! Your 1st UOA is an exciting moment!
I don't think you know how to post a UOA. You can't just copy and paste a .pdf.
