I need some guidance from the experts.
Have a 2012 Camry AT with 17,000 mi. From reading a lot of the posts, I should and want to change the AT fluid and filter. What I’m looking at doing is draining the trans, removing the pan and replacing the filter. I read that’s a very important step with the original fluid change. Replace the filter, pan and add fluid until it comes out the add plug. I also read that the fluid needs to be at the proper temperature when adding it. WHAT IS the “Proper temperature?” Do I add room temp fluid until it’s at the top of the add hole?.....I would think you want to be a little less than that to take care of the fluid when it gets to operating temperature
Is there a better way or getting more of the fluid out of the trans than just by draining it?
What’s the best gasket cement to use?
Thanks
Lloyd
Thanks
Lloyd
