First oil change / Pacific Hydrostar 6.5HP
South Florida
I just reached 5 hours on a Pacific Hydrostar (Harbor Freight 6.5 Predator engine) pressure washer.
The initial fill was 10W30 Valvoline Nextgen and was FULL of glitter/aluminum. Pretty shocking how much glitter was in the initial fill. Hopefully that will level off after an oil change or two.
I used the engine on full throttle for a solid three hours today non-stop (85 degrees). I thought to myself that the oil was probably taking a beating. So with that in mind, I changed the oil and replaced it with Valvoline VR1 synthetic 10W30.
Mini pressure washer review:
Ran excellent, started easily, used about 3/4 of a tank during a three hour run and didn't even need refueling. My old 13HP Subaru pressure washer would go through about 5-6 gallons of gas in 2 hours, so this engine is about 5 times more fuel efficient!!
The unit has plenty of power and zaps mildew away efficiently. This is a perfect unit for a homeowner in my opinion.
