My Auto-Rx will be arriving soon so a question.
This will be used in a mopar 3.3L V6 and 4 speed
auto trans, both with 191K miles.
The motor is using 1 qt./1200miles and the trans
reciently started leaking from the bell housing.
Currenty running Super Tech 15w40 HDEO and a Motorcraft
FL300 filter.
I also have MC FL1 filters, which I intend to use
during the rinse phase.
Should I use the larger filter during the clean
phase as well, or doesn't it matter?
As far as the trans goes, if ARX helps the leak,
probably from the torque converter nose seal,
thats good, if not I'll have to pull it and replace the seal, which I would have had to do
anyway without the ARX.
Wayne
FL300 filter.
Wayne
