After much thought/research, I've decided to use Auto Rx on my 97 T-bird with 87,000 miles(currently consumes Pennz.HM 10-30 at 1/2 qt/2,600m), and have a few questions
Main reason to do Auto Rx: switched directly without flush from conventional to full synthetic at 82,000m, and started above consumption)
1) when changing oil after clean/rinse cycles, is it really important to let the oil darin for a very long time?
2) I'm planning to add Auto Rx at next oil change with probably Dino Motorcraft/chevron 10-30(for both clean/rinse phases); are these oils ok to use with Auto-Rx? are there any special brands which work better?
3) going to do clean cycle for 1000 miles,and rinse for 2000 miles; using Motorcraft FL-820S filters and above oils; plan sound OK? any mistakes?
4) Not yet decided on the oil after rinse...if I get good results, probably GC 0w30 or Chevron or Pennzoil High Mileage 10w30.
Thanks so much for all the advice ao far, and in advance for answers to the above....
