Filtran inline atf filter 20k miles
Texas
This is a second inline filter I put in the return line from the cooler on a 2019 grand caravan with a 62te transmission. This transmission was rebuilt right around 100k miles and now has 124k miles. I had put a Raybestos in there before I took it to the transmission shop in case there was any debris stuck in the cooler after the rebuild. It was on for about 2k miles. I didn’t open that one up though I wish I would have now. It might have caught a lot of early break in seeings how this second filter caught a lot.
With that much in the filter, I’d be surprised if it makes it 100k. Wishing you the best since tranny rebuilds ain’t cheap. 👍🏻
Thanks for the pics. Can you get a Magnefine in there?
Thanks . Yes the magnfine is pretty much the same size as this Filtron. I’ve seen a lot of metal in transmission pans and on the pan magnets before in some models. Usually after the first fluid flush there isn’t a lot of metal or debris to see on following examinations. I guess we shall see with this one.
