One way to know for sure is to measure the pressure before and after the filter to determine restriction. For a given install there would be a safe range. I betcha that many filters can *easily* go 2-3 oil changes and still be going strong.
If you run a drain valve you can dump and fill your oil extremely fast with no tools or mess and just run the filter longer. If you run a thermostat equipped oil cooler you better flush the lines or at least get the oil hot enough to circulate that semi-trapped fluid.
If you are worried about leaving old oil in the engine…guess what, you already do that now. Especially in oil cooler equipped vehicles.
If you really want to get old oil out do a change, filter swap and then another complete change after a few minutes of running the first-changed oil. Drop the pan, pull the valve cover and clean it up. Or use one of those powerflush rigs where they hook up hoses to the engine.
