filter bypass valve
indiana
i have heard drawing oil through ( vs pumping through ) a spin on filter eliminates the bypass valve inside...
is this true...
im trying to set up a waste oil filtration system using mostly used 30 / 10 micron oil and fuel filters then a centrifuge and then new 2/1 micron filters
thanks
ok thanks thats what i figured...
im not sure if the filters have them them or not ... i get them free used from semi fleet maintnance
they only run 10k on all fuel and oil filters , and i get to take all the used oil i can store...
ill just have to swap filters every 50 or 100 gallons
its mostly to reduce waste in the centrifuge im currently trying to piece together a 15 gall batch system using scrap materials
my 2 micron fuel filter will completely stop flow
