I have used several oil filters, but wondering which will suit different applications. The Stratus V6 seems to be sensitive to low flowing oil filters (valve train chatter, ticking, oil light on at hot idle, etc). This has only happened with Fram and a Pure One after 2000 miles. Readily available are Super Tech, WIX, Napa Silver wix, Motorcraft, Purolator, the Advance Auto purolator and K&N. Which will filter the best? Which will flow the best? For a travel through the dessert at high speeds, is there a recommendation for best flow at sustained higher rpm's? The Purolator filters seem to give good results, but any good advice for driving conditions? I think the K&N flows very well, but does it compromise filtering? Thank you for the help!
