G Gebo Joined Sep 18, 2002 Messages 6,371 Location VA Aug 27, 2025 #1 Do you know the temp range to check ATF level in ‘23 GX460? I think it’s the A760F???
0 02SE Joined Dec 30, 2005 Messages 9,211 Location the canyons Aug 27, 2025 #2 . Last edited: Aug 27, 2025
thescreensavers Joined Dec 21, 2009 Messages 1,355 Location WPB, FL Aug 27, 2025 #3 Gebo said: Do you know the temp range to check ATF level in ‘23 GX460? I think it’s the A760F??? Click to expand... pin thermostat, turn on vehicle, let it idle until trans pan temp shows 115F-126F, then pull overflow plug until trickle.
0 02SE Joined Dec 30, 2005 Messages 9,211 Location the canyons Aug 27, 2025 #4 According to the manual 115-126° F. My advice: Make sure you familiarize yourself with the procedure, before attempting it. Well, those screenshots aren't working. Find a copy of the service manual online. Last edited: Aug 27, 2025
J Johnny248 Joined Jul 19, 2009 Messages 2,800 Location Detroit, MI Aug 27, 2025 #5 thescreensavers said: pin thermostat, turn on vehicle, let it idle until trans pan temp shows 115F-126F, then pull overflow plug until trickle. Click to expand... This is the same as other Toyotas I believe? My Tacoma has a Park/Neutral sequence which will show you when the transmission fluid temp is within range. I wonder if these new Toyotas do also?
G Gebo Thread starter Joined Sep 18, 2002 Messages 6,371 Location VA Aug 28, 2025 #6 I’m very familiar with procedure. I just didn’t know the temp range. It’s easy peezy if you have a scanner that reads ATF temp. Thank y’all.
