Originally Posted By: 97tbird
I remember they always had this problem, I am wondering if you guys know of a fix for FF suddenly using a bunch of resources...as soon as I close FF, CPU use goes down drastically...
That's a lot. Check to see if your Flash is stuck. However, that problem seems to be solved now, and when it was happening, closing the browser didn't shut down Flash, and the usage stayed high. If you check your processes, the Flash is called npviewer.bin, if I recall correctly. Be sure there aren't multiple instances or one hung instance.
My CPU usage is nowhere near that. I am using 10.04, so it may be a different set of issues. Did you check the Ubuntu forums?
