Favorite battery powered lawn mower that’s very reliable ?
FL
What’s the most reliable brand of battery operated lawn mowers under $500 ?
I do understand a high quality rechargeable battery increases the cost, which is perfectly fine.
I have a Kobalt 20" 40V 3 in 1 that I bought from Lowes a few years ago. I really like it, the best feature is how smooth and quiet it is. It came with 2 batteries which is more than enough to do my lawn (about 3000 sq. ft.). I swap the first battery out before it dies and I use maybe 25% of the charge on the second battery worst case. Our lawn used to be larger (as we add features the grass amount shrinks) and I would fully use both batteries, they were more than enough and the recharge time isn't very long. The only charging issue I have had is in high ambient heat, heavy loads and if I put the battery in the charger right off a cut it flashes the charger's high battery heat LED. I just let the battery cool and it is fine to resume charging, meanwhile I am on battery #2 anyway.
