If you've ever seen the matrix of a ductile iron crankshaft at high mag (~100X), you'd find that it's essentially made of tiny spheres of graphite in an iron matrix. The graphite has no strength and can be considered voids for this discussion. When this matrix is machined, the tool cuts through these holes and forms micro-burrs over these holes. If not properly finished, these burrs can lift up and damage the bearing during service. I've studied this in great detail. I've seen burrs that are long enough to lift up and extend across the bearing clearance thickness.
The accepted way to finish a ductile iron crankshaft journal surface is to grind it in the opposite direction of service, then polish it in the other direction (same as the service direction). Grinding produces the burrs facing in one direction. Finish polishing is then supposed to lift up and remove these burrs, making the crankshaft journal surface suitable for use.
