I took my car in for a smog check this past weekend and I failed the 15MPH test. HC was high. NOx and CO are fine. The spark plugs are clean - the old ones had light gray deposits on them. This points to a misfire but the car seems to run fine albeit it's been using a little more gas than usual when I do drive it. I also checked the O2 sensors and while the CEL isn't being thrown, the readings never went above .5V, it stayed between .2-.4V. I'm thinking my O2 sensors are lazy, but also I recall driving back home when suddenly I lost power due to a failed coil wire - I was running on 4 cylinders and dumping raw fuel into the cats for 5 miles. Could the cats be shot, but if they were wouldn't all the HC/CO/NOx readings be off the charts?
https://drive.google.com/file/d/0B_wxerr_NAqBMkJuMVVvX3A5R0U/edit?usp=sharing
