Interesting one here, I have no idea what oil the dealer installed in this thing but I don't believe it was 15w-40 HDEO. Super low hours (27h) but oil was in the unit since it was purchased in Oct 2021 so I wanted to flush that out, get a baseline, and develop our moving forward strategy. Now that I'm taking over maint for this unit, we have a plan to run monthly and will get heavier usage this fall while shredding a 50 acre klein field.
Any idea what factory fill they used here? Rotella T4 15w-40 was what went back in. Below are the results from the first sample sent to OAI.
Make/Model: V3307-CR-TE4 Diesel Engine
Vehicle: 2021 Kubota M7060 Tractor
Oil Filter: Kubota HH1C0-32430 (Replaced with Wix 57430 during OCI)
Location of use: Brady, TX
Sump Capacity: 12 Quarts
OIL FF 15w-40
MILES IN USE 27 hours
MILES ON UNIT 27 hours
SAMPLE TAKEN 7/21/25
MAKE UP OIL 0
IRON 5
CHROMIUM 0
NICKEL 0
ALUMINUM 2
COPPER 8
LEAD 0
TIN 0
CADMIUM 0
SILVER 0
VANADIUM 0
SILICON 14
SODIUM 7
POTASSIUM 164
TITANIUM 0
MOLYBDENUM 159
ANTIMONY 0
MANGANESE 2
LITHIUM 0
BORON 177
MAGNESIUM 11
CALCIUM 2860
BARIUM 4
PHOSPHORUS 432
ZINC 486
Fuel Dilution 1.8%
Soot <.1%
Water % <.1%
Visc @ 100C 9.8
TBN 8.49
Oxidation 5
Nitration 6
Lab comments:
Maintenance indicated at time of submission, no further maintenance action is required at this time. However, Viscosity is SIGNIFICANTLY LOW. Causes include contamination, incorrectly identified viscosity grade, or adding a different viscosity grade to the component. Increased component wear possible. Lubricant and filter change acknowledged.
OIL FF 15w-40
MAKE UP OIL 0
IRON 5
CHROMIUM 0
NICKEL 0
ALUMINUM 2
COPPER 8
LEAD 0
TIN 0
CADMIUM 0
SILVER 0
VANADIUM 0
SILICON 14
SODIUM 7
POTASSIUM 164
TITANIUM 0
MOLYBDENUM 159
ANTIMONY 0
MANGANESE 2
LITHIUM 0
BORON 177
MAGNESIUM 11
CALCIUM 2860
BARIUM 4
PHOSPHORUS 432
ZINC 486
Fuel Dilution 1.8%
Soot <.1%
Water % <.1%
Visc @ 100C 9.8
TBN 8.49
Oxidation 5
Nitration 6
Lab comments:
