Factory Fill -1,451km -2010 Ford Focus 2.0L Petrol
Townsville, Australia
Html:
OIL Factory Fill
OIL KLMS 1415
MACHINE KLMS 1415
SAMPLE TAKEN 15/5/2011
SAMPLE VISCOSITY
@40c cSt 50
PARTICLE COUNT(1-100) 30
PARTICLE SIZE %:10um 99%
PARTICLE SIZE %:10-20um 1%
PARTICLE SIZE %:>20um 0%
RUBBING High to 10um
CUTTING High to 10um
FATIGUE High to 10um
PARTICLE CONTAMINATION High
METALS
ALUMINUM 7
CHROMIUM 3
IRON 16
COPPER 27
LEAD 1
TIN
NICKEL
CONTAMINANTS
SODIUM 2
SILICON 44
ADDITIVES
BORON 11
MOLYBDENUM 4
CALCIUM 2551
MAGNESIUM 9
PHOSPHORUS 784
ZINC 920
SULPHUR 3185
WATER pre>
Comments on report:
Wear metals are at high levels in spectrographic results and high in microscopic report although particle size is small.
Silicon is high which may be due to sealant contamination. Viscosity appears low for an engine oil. Elevated levels of
wear metals and silicon levels are consistent with run in period. Expect levels to drop with oil changes which is
recommended. Please check intake ducting system as a precaution against dust entry. Resample at 1500 klms as wear
particles may be abnormally high in numbers.
Driving Conditions:
All city driving
Fuel economy: Approx 10L/100km
Refilled with: Fuchs GT1 0w20
Filter: MC AFL4
Next change will be made in Feb 2012.
What is Fords recommended OCI? Is your gas mileage that high? My Spec-V gets that in city driving!
Wear #'s high due to new car break-in, they want you to pay for another UOA in 1500km's!!!???!??!?
That is ridiculous! Everything looks normal and they should/do know wear is generally high the first couple of oil changes for a new vehicle. I would not waste my money on used oil analysis until you get to around 25,000km or so. Just my 2 cents. Everything looks as expected, good luck!
Yea I do, apart from the plastic intake manifold and that it doesn't have a PS reservoir. We get the UK model over here. The global focus comes out later this year.
