Factory Fill -1,145km -2010 Honda CR-V 2.4L Petrol
Townsville, Australia
Code:
OIL Factory Fill
OIL KLMS 1145
MACHINE KLMS 1145
SAMPLE TAKEN 24/5/2011
SAMPLE VISCOSITY
@40c cSt 53
PARTICLE COUNT(1-100) 35
PARTICLE SIZE %:
PARTICLE SIZE %:10-20um 2%
PARTICLE SIZE %:>20um 1%
RUBBING High to 30um
CUTTING Med to 10um
LAMINAR Low TO 75um
FATIGUE High to 20um
PARTICLE CONTAMINATION High
METALS
ALUMINUM 16
CHROMIUM 4
IRON 11
COPPER 30
LEAD 2
TIN
NICKEL
CONTAMINANTS
SODIUM
SILICON 41
ADDITIVES
BORON 109
MOLYBDENUM 275
CALCIUM 1622
MAGNESIUM 7
PHOSPHORUS 802
ZINC 781
SULPHUR 2621
WATER pre>
Comments on report:
Wear metals are at high levels in spectrographic results and high in microscopic report with particles visible to 75um.
Silicon is high which may be due to sealant contamination or dust ingression. Viscosity appears low for an engine oil
although is not considered abnormal for a running in oil. High levels of wear metals and silicon could be caused by dust
which is showing high in particle count.Resample at 1000 klms to check wear levels and check air intake system.
Oil change is recommended to flush compartment and restore oil condition.
Driving Conditions:
70% city 30% Highway driving
Fuel economy: Approx 10L/100km
Refilled with: Fuchs GT1 0w20
Filter: Honda
Next change will be made in 6 months, as per Honda servicing.
Note: I was not present for sampling, dealership did it.
Many on the "CR-V" forums would burn you at the stake for draining the precious Honda Break in Oil early.... but I'm with you brother. I drained my 2010 CR-V oil at about 1000 miles and put in Mobil 1.
Hasn't blown up yet!
What vis Oil do Honda guys run down under?
Have never seen a particle count presented that way but it does show the break-in process quite well, doesn't it?
Maybe the answer to leaving the break in oil in longer (I cringe at the thought) is to change it early but use a similar oil to replace it? That first thou or two mile (or klicks, as the case may be) is when most of the gunk will be generated. You could run the second fill out to a short OCI, say 3K, and then run normal OCIs and normal oil after.
Originally Posted By: Jim Allen
. . . Maybe the answer to leaving the break in oil in longer (I cringe at the thought) is to change it early but use a similar oil to replace it? That first thou or two mile (or klicks, as the case may be) is when most of the gunk will be generated. You could run the second fill out to a short OCI, say 3K, and then run normal OCIs and normal oil after.
Another option is to change the original oil filter at, say, 1k and stick with the FF (gotta love that moly) for 3k or more. I've done that.
The reason why so many automakers say to leave all that junk floating around in the FF for the duration of the OCI is a huge mystery to me (and everyone else on this board, i'm sure)
I personally dumped the FF @ 1k on both my 2007 Civics and replaced it with Valvoline HM (supposedly had loads of moly in it at the time, i don't know if it still does today, its not an oil of interest to me anymore)
Some say the fine particles of metal shavings help to "polish" the engine internals and remove any rough surfaces which in turn should prolong engine life. I feel that 1,000 miles of that stuff splashing around is long enough though
ammolab - It would have more kms on it but it hadn’t been driven that much during its 6 month service interval. The aussie manual states viscosity from 0W30 to 15W40.
Thats interesting. They call for 5w20 over here in the states. I wonder if it's just because of cafe reasons or if they build the engines differently over in australia.
Actually, for 2010-2011, it's 0W-20. Why else?, and no.
15w40 is just crazy!!
unless its like Super HOT over there or something.
I'd stick with a nice juicy 5w30 for the K series engines, esp if you tend to run them HARD. Otherwise i think 90% of the engines driven normally would be fine with a 5w20 or 0w20.
You can't convince me that Honda builds a "Different Spec." motor for every market they send cars to. I also don't think USA bound Hondas have a single difference than those Aussie CR-Vs running 15W-40 oil.
I have a Japanese Built 2010 CR-V and may well put in something a bit 'stouter' than 0W-20 next time I tow my Motorcycle trailer across Texas in summer heat at 85mph.
It isn't a mystery to me and there has been little evidence produced to show that replacing the Honda factory fill does much of anything except lightening your wallet.
The Honda FF has shown to be of high quality and a genuine break-in oil. Even the owner's manual explains to keep it for at least 7500 miles or go by the MM.
I'm sure it won't hurt anything either route chosen.
